WTB Centerline lug nuts
TrackPack
8:26 AM
Minnesota
Feedback: 3 / 0 / 0
Looking for two packages of Centerline L-5110 lug nuts. These are the 1/2" open ended ones for Convo Pro wheels.
Some of the lug nuts just have pressed in caps. I used those back in the day on my 3" studs just kept threading them on and they pushed out.
The L- 5110's are 1/2 x 20 right hand thread. Shank is 1/2" long, and hex is 13/16"
Unless you MUST have the Centerline lug nuts, look at Cragar lug nuts or similar ones at parts stores. Otherwise, check e-bay and keep looking for some to show up. Hope This Helps!
Measure the shank length of the centerline lug nuts and then just buy lug nuts with the same shank length...that is all that is necessary. Those Centerline lug nuts are no different from any other shanked lug nut with the same shank length. MOST Center Line wheels use a lug nut with a shank length of 1/2" (0.50") with a shank diameter of .680. CL-5110 lug nuts are spec'd with 1/2" shank length.
If you don't have any of those specific Center Line lug nuts to measure the shank length then measure the thickness of your Centerline wheels thru the lug nut hole and then buy lug nuts that are a just a little shorter than that length. If you buy lug nuts with a 1/2" shank length they should be fine. After you buy them then insert 1 of your new lug nuts thru the lug nut hole. The shank of the lug nut MUST NOT protrude thru the lug nut hole all the way or the lug nut will bottom out against your hub before the lug nut clamps the wheel tight. It can't even be 'flush" with the back side of the wheel. There MUST be some clearance between the end of the lug nut and the back side of the wheel.
Check the nuts with this method. If the lug nuts you buy with 1/2" shank length don't even insert half way thru the wheel then they are too short. Get longer ones that insert at least 90% thru the hole without going flush with the back of the wheel.
Having been in the Mag Wheel Manufacturing business for some 20 years I know this for a fact.
Couldn`t a guy buy longer ones and just cut them down to what he needs ? I did that on some fake center lines that have uni lug, I wanted them as long as possible----
I'm kind of in the same boat with my Motor Wheel Spyders.
VERY specific nuts. The have a conical seat and a bottoming shank.
ET nuts are similar, with the cone, but too long of a shank.
I've considered milling off the bottom of the shank, but was concerned about rust on the newly milled surface.
I get the Gorilla brand from summit. They have nice chrome.
Thanks for the replies.
I have two packs of Centerline L-5110's and the shank diameters measure .643 and fit the Convo Pro wheels perfectly. I found a later produced pack that measure .648 and are very tight (quality control issue?) The shank lengths all measure .490 so no problem there.
I did try a set of McGard, but the shank diameter is .640 and these are sloppy loose.
I`VE RUN INTO THE SAME THING, I TAKE THEM DOWN IN A LATHE IF TOO BIG------
