TQ, 440, and vacuum advance
Sonny
2:40 PM
Florida
Getting ready to start playing with the vacuum advance on my ‘78 440 with a ‘78 thermoquad. Has a slightly lumpy cam and vacuum at carb is about 15”. Any recommendations on where to start with base initial timing? I’m running initial timing at 17 and total 36 right now without VA. Looks like there is only one vac port on the TQ at the plate on the front/driver side.
Im no pro but had to mess around with mine last summer. Close to same set up, 76 440 , cam , 14" vac, 750 eddy.
I ended up with 16 initial 34/35 total , all in at 2500/2600 had a surge above 3500 under load.
no popping or missing just that pesky surge, Got some good advice on here.
I hooked to ported vac and it helped lesson the surge still was there but not bad. I ended up putting a size stiffer spring { pink } in carb and reset the float levels and that finished it. no more surge, starts fine when hot, runs great.
Thanks. My Thermoquad only has manifold vacuum. I’m trying to find out what is the initial timing before plugging in the vacuum advance. I realize every engine is different, just trying to find a good starting point.
Just hook a vac gauge to that nipple, at idle then up the rpms. Mabey someone who knows more about the Tquad carbs will post.
But the gauge will tell you pretty fast, or heck just start it and at idle pull the cap and see if the idle drops like it has a leak.
Dr side front nipple right of the idle mix screw is where you hook up the va to the dist.
16 19* int is a good start
Connect to manifold vacuum and make sure the canister is mostly pulled in at your idle vacuum of 15".
Your light throttle cruising vacuum will be higher and will completely pull in the ignition advance.
