- 3:31 PM
- Jul 31, 2011
- Western Colorado High Desert
StratOvent water valve has vacuum lines on the pass side.
I think it is for the tach but I'm a bit confused about the 71-4B tach wiring. I've seen the stand alone tach harness and think that is the hole for it but the cars that I've owned and ones that I've worked on didn't have the separate harness. The tach wire was in the bulkhead as seen here on this 71 V code RR with factory tach. The grey and black wire goes to the coil. I do have a couple of the stand alone harnesses , can't remember where I got them
