Roughbird72
- 12:48 AM
- Oct 18, 2014
- North Central Indiana
How much shim would be too much to be safe?
No Doug, housing mounted in the car and it is on stands.Most Mopar pinion C/L to perch are 5 degrees up from the factory (measuring the axle housing loose out of the car). Is this how you are measuring? The perch to the pinion? If so it may be very close. If it's 4 degrees up in the car, what is the trans C/L angle? I'm assuming you are measuring with the wheels on the ground if it's an in car measurement.
Agreed, if you can weld I'd just cut them. We now weld tabs at the perch ends to the housing as gussets. I've cut mote than a few off myself.No Doug, housing mounted in the car and it is on stands. Spring perches are cheap, so it's just a matter of an afternoon's work.
I shoot for pinion 3-4* nose down relative to crank centerline. Pinion nose swings up under acceleration.
What is ur trans angle like. Up/down/zero? U need that measurement also, then add or subtract the difference. KimWith a 4° shim, the leaf springs mounted in lower hole of the front brackets and the weight of the car on all 4 corners I ended up with 5.5° negative angle.
