Column shift to console conversion question?
Devjas
4:57 PM
Kleinburg, Ontario
Im going to convert to console shifter on my 69 Charger and want ask you all if anyone knows if there is a complete parts list available so I can search out parts to order..
thanks in advance
Console shift column. Manual steering or power they are different lengths. Found one here
Console shifter HERE
Console linkage HERE
Console ebay HERE
Console brackets for mounting. HERE
This picture should give the info you seek.
No problem.. glad I could help a little.
Bravo BeepBeepRR….you did everything but buy/install it!
I've always "thought" an easy way to install an automatic floor shifter (not trying to be original) would be just to install a cable-operated performance shifter and line it up so you could use a factory console. I saw a guy years ago that did this & made a custom mount for the shifter out of a block of wood that you couldn't see at all once installed in the column.
Lol i was bored.. So thought I would help a fellow mopar guy...
