toppers33
Hi, I'm hoping someone can help. I have a 1966 Dodge Coronet HT 383 auto. The car is in the UK. Last winter I replaced the engine harness and engine side of the bulkhead connector. The headlights, both low and high beam are now halogen and fed via independent relays.
The instrument cluster gauges including speedo were either broken or innacurate. These have now been repaired and ready to re-fit. This winter I have started replacing the dash harness and interior side of the bulkhead connector whilst I've got good access.
As the car is used in the UK the back up lights have been disconnected and the housings are now used as direction indicators with amber bulbs. The violet wires to the rear back up lights are now redundant as is the back up switch (auto box).
1.What does the violet and white tracer wire coming from the wiper switch terminal post B do? I've removed the violet to the back up lights but can't work out what the violet with white tracer does? It goes to the 'console connector' on wiring diagram.
2.Also why is it indicated as a dotted line on the schematics as is the pink wire?
I'm adding in a few circuits and removing those not needed.
Any pointers appreciated. I'm sure it will be a simple answer.
Thanks,
Lee
Thanks,
Lee
