Well that explains it, then. Any material removed from the deck is going to result in the piston being above deck. You could have just used a thicker gasket as Stanton did, eliminating the fly cut and re balancing. Then you can dial in your quench distance/clearance with the gasket thickness. If it's .010 above, just use a gasket around .040. I'm building a 512 also. Same set up as you, except flat top pistons. Pistons will be at zero deck before block surfacing. I plan to have the block cut .010, and use a .040 gasket. I work out all this on the computer beforehand, so I kinda know how to proceed. I'm shooting for around 13 to 1 C/Ratio, as this is a race only motor.Rod length 6.535 piston-24 dish 0 deck and 1.320 compression height.
I'm too lazy to calculate...… but, it's basically 8 x cylinder volume, which includes thickness of the head gasket, stroke, piston volume, combustion chamber volume, etc. So.....if there is no other change than the heads, & combustion chamber volumes are 88cc (?) & 78cc (?), then your CID of the engine is 8 x 10cc = 80cc = about 5 cubic inches smaller with closed chamber heads vs. whatever you had with open chamber heads.Ok, let me ask you this question. I have a 440 with 906 heads. I replace it with 915 heads. Nothing else changed. What is the new C.I.D. ?
It’s 440 cubic inches regardless of what head is on it. Hell, it’s 440 cubic inches with no heads on it.I'm too lazy to calculate...… but, it's basically 8 x cylinder volume, which includes thickness of the head gasket, stroke, piston volume, combustion chamber volume, etc. So.....if there is no other change than the heads, & combustion chamber volumes are 88cc (?) & 78cc (?), then your CID of the engine is 8 x 10cc = 80cc = about 5 cubic inches smaller with closed chamber heads vs. whatever you had with open chamber heads.
Hmmm....maybe I'm wrong on this. So, are you saying the cubic inches of the motor does not include the combustion chamber volume (& head gasket)????It’s 440 cubic inches regardless of what head is on it. Hell, it’s 440 cubic inches with no heads on it.
You must be thinking of compression ratio.I'm too lazy to calculate...… but, it's basically 8 x cylinder volume, which includes thickness of the head gasket, stroke, piston volume, combustion chamber volume, etc. So.....if there is no other change than the heads, & combustion chamber volumes are 88cc (?) & 78cc (?), then your CID of the engine is 8 x 10cc = 80cc = about 5 cubic inches smaller with closed chamber heads vs. whatever you had with open chamber heads.
I thought they might! Chrysler was maybe testing out an idea when they built that 1 year 383 Magnum with a positive deck piston. I will have a positive deck height in my 512 build.Sometimes they sit a bit proud. No worries, they run well like that.
View attachment 718236 View attachment 718237
So if your Pistons are slightly positive deck and you are worried about "quench".... why not just substitute the Fel-Pro 1105 .051" Head Gaskets ?
Who cares if the Pistons are slightly outa the holes ?
