Skytrooper
1SG (Ret.)
Anybody running this setup ? Any reason not too ?
I'm runnin it on a 64 dodge.Anybody running this setup ? Any reason not too ?
My 73 sebring has the same combination 14s on the front and 15s on the back.the car was like that when l bought itAnybody running this setup ? Any reason not too ?
I believe your 73 only came with 14's and that would be on all four corners.My 73 sebring has the same combination 14s on the front and 15s on the back.the car was like that when l bought it
Not a problem, you can put almost any size rim on as long as you keep the overall height about the same. If you were to put 20's on it the tire would be more like a rubber band and a 13 the side walls would be much taller. See where I'm going.Forget this whole conversation lm going to start again! Will l have any problems using 15 inch rims on my 73 satellite sorry about the confusion guys![]()
Thanks for the information its much appreciatedNot a problem, you can put almost any size rim on as long as you keep the overall height about the same. If you were to put 20's on it the tire would be more like a rubber band and a 13 the side walls would be much taller. See where I'm going.
Been a few years but just interested if you have more pics of your wheel set up with the 14s and 15s?Had mine that way for over 20 years.View attachment 673930
