Spindle help please
Knoxville
10:31 AM
West Dundee IL
Hello all. Need some help please. I'm going to buy a Wilwood drum to disc conversion kit for my 67 Belvedere II. The issue is a rep from Wilwood has the kit for a 67 Belvedere but not one for a Belvedere II. He is asking me if the spindles are the same between the two cars. I dont know the correct answer to that question. Also, I'm buying a QA1 stage 3 suspension kit to install at the same time. Any accurate info about the spindles would b greatly appreciated. Thanks to any help. Jon
All the b body drum spindles are the same from 66-70 so you should be good
Not sure if you are going for Resto, or Restomod or Race car... The spindles DID change on later cars. Those later spindles can be easily fit to your car and allow for a wider set of disc brake options (and bigger bearings, options for dropped spindles, etc.). I did that when I converted from drum to disc using Magnum Force spindles and I'm really happy with the outcome, but it is also possible to just use stock later model ('73 and later) spindles. Just a thought.
Just a couple other random things to remember (excuse if you already know these or it doesn't matter on your conversion): If you change to disc in front and drum in rear the braking is a little odd as the drums are a self energizing design and the discs are not. I needed a proportioning valve to straighten this out until I switched to four wheel disc. If you do change to four wheel disc, the rear wheels bearings change (I think on all the early mopars) from the stock style to the "green bearing" style, that is, from the angled bearing to the flat bearing. The flat bearing is by many accounts actually less good than the factory style. I changed over and haven't seen any negative effects yet even after a couple of track days and driving like a moonshiner when the mood strikes me...
Hey Grabinvo. So just to be clear. I can buy spindles for a 73 b-body and they will fit my 67 with no fab or modifications and that will give me more options for disc brakes. I would really rather go with 6 piston set up than four. What you are telling me is rite there with what the rep from Wilwood said. Can I buy the 73 spindles new or do I have to find used?
If you look in my thread called "80 Grit" you'll see how I did it on my '70 Roadrunner using the aftermarket spindles. But the short answer is yes. I am not sure you can buy '73 spindles new, but they'd probably be SO expensive (New Old Stock) as to not be worth it. There are a number of companies that sell them though. they just call them "Big bearing - '73 and later spindles". ^ piston! Awesome! Wish I had done that - Make sure your wheels will fit over them. Most require 18" wheels for the huge brakes.
You mentioned QA1. If that's who you're using for front suspension I bet you can buy their spindles. Here are the Magnum Force dropped versions:
http://www.magnumforce.com/magnumstore/shop/item.aspx?itemid=5
Just an example i found real quick. these appear to be the '73 and up A-Body spindles - same thing...
https://www.performanceonline.com/1962-74-MOPAR-A-B-and-E-Body-Disc-Brake-Spindle-Kit/
Thanks for those links sir. I was looking around and came across a conversion kit that claims to bolt rite up to what I have. Do you have an opinion on Leed brakes? Reviews are all 4 n 5 stars. Price isn't bad either.
I don't know them but there are some posts on here that seem to describe them. Those kits don't come with spindles from what I can tell so they must be mounting to your existing factory spindles.
