Don't Use Headliner Material to Cover your Sun Visors ...
Dibbons
8:34 PM
La Paz, B.C.S., Mexico
... or they will come out wrinkled.
Now I have to ask, when I do the visors over again, what color should they be? With the original tawny gold they were gold, with the first blue repaint they were blue, and with the current Bahama Yellow and two-toned interior I can't decide.
Those weren't done by a professional were they?
He used to do good work, now furniture is piled higher and higher in his shop every week, he is falling way behind, and is quality of work is no longer acceptable--in other words, he has lost it for some reason.
At least he could have told me the headliner material was too stretchy to work well on small items.
I'm no upholstery man, but I wonder if the headliner material might have worked better if it was glued to a backing such as a layer of thin felt to fatten it up a little, before he started cutting it up and trying to work those edges where it puckered. They should have been finished with a thin strip over the entire edge all the way around anyway, I do believe. HTH, Lefty71
Hence my comment in post #2.
try using a heat gun on the visors.. it does shrink.. just dont do it so close where it melts.. they use a heat gun on the wrinkled areas of a headliner to tauten it up..
