Common Resto Parts they don't make for 66 / 67 Chargers
Maxrat
3:15 AM
Virginia
Correct drivers side remote mirror adjusting handle. The stainless rocker panel trim plastic clips. The gasket for the trunk lock escutcheon. The D O D G E letters on the hood. The black gasket material that goes on the top of the tail light housing that fits against the body. A full proper kit to install the long fender, door, quarter aluminum trim. The triple window regulator rollers. Know of any others?
Grill.
How bout the correct trunk lock?
I made a later one work by eliminating the bezel though.
Quarter skins
Headlight stuff.
The longer rear window stainless steel trim clips that go on the sides. They make the top and bottom clips -- just not the sides.
They don't make the odd shaped screws that hold the rubber rear bumper filler strip / seal.
Do you happen to have a picture of the screws that you mention that holds the rear bumper filler strip in place?
Here's some pictures of the rear bumper filler strip screws.
Maxrat, thanks for the pictures of the screws. I have never seen that one before and checked several of my sources and did not see anything 100%. I will keep my eyes open for a source and forward the pictures to some of my suppliers.
69bfan, are you a dealer / supplier? If so, I'd really like to find a nice set of window fuzzies for the 66 Charger. Someone on this forum said they got a set where the clips that hold them in weren't long enough. The 66 Charger fuzzies don't clip straight to the body -- they have to go through stainless steel trim, then to the body.
I will check where I got mine. Picked up quarter panels for front and back. Back ones needed some fitting but the front ones fit well. What other metal were you looking for.
I'm not needing any right now.
But would like to know what is available for other people and future reference.
RockAuto had the best price for front quarter panels, but not sure if they are restocking. Classic had Coronet rear lowers that I modified some to work on mine. They are out there, also some full panels too, just need to look.
Coronet quarters are quite a bit different in the critical wheel well area.
I've seen Charger "from the body line down" full skins, which are not available for Coronet.
