Mr. Belvedere II
Thanks for taking the time RT! Im thinking the same thing. About ten years ago I sent it all to the machine shop for magnafluxing and decking and bore/ hone. The heads were Edelbrock RPM and new at the time. Same with pistons, cam, lifters, timing chain, rockers, pushrods, and lifters. Pretty much a brand new build so I’m hoping a lot of it can be reused. The machine shop built the short block then me and my mechanic did the rest. I bought most of the gaskets already soooo.Being that it was rebuilt and not ran much, you could probably get away with a light hone if the cylinders are in nice shape or maybe just clean them up with no hone at all. The bearings, those I would replace because antifreeze is very corrosive to them and for the few hundred bucks, it is cheap insurance. I'd have the block hot tanked and see what it looks like corrosion wise and go from there. Id check the flatness and surface finish on that deck surface and the heads and make sure it's flat and wasn't leaking there because of that. Also was the block magnufluxed for cracks? That's ALOT of coolant inside that engine for a small leak unless it was run for some time like you said. $750-$1000 in gaskets and small parts is cheap insurance for the long run if you want it to stay together and provide years or service.
