koosh
If I decide to try this power steering box I have, and found used pump on Ebay , is there somewhere I can get just the steering main shaft? Am told I will need to change since manual steering has different length shaft?
So does this go on where ever I cut existing manual st6main shaft?, does it fit right onto factory power steering box?http://www.flamingriver.com/index.php/products/c0008/s0009
I used their joint to replace the rag joint.
i have a complete column 135 shipped
Goes on the box,then you might have to trim the shaft to fit.So does this go on where ever I cut existing manual st6main shaft?, does it fit right onto factory power steering box?
it's from a 67 charger and its red power steering column shiftWhat color? From what car/year? Condition/pics? Trying to track down a P/S floor shift column for a 69 Road Runner. Thanks
