Need help , what top and bottom hoses will work ?
funnykarman
8:20 PM
Newnan Georgia
I think that a Off the shelf top and bottom hose will work for a 65 thru 68 New Yorker , Bottom hose is on pass. side and top on driver side . Looking to try and find formed hoses . Let me know what you thing might work . What types of mopar cars or trucks use this set up . Thanks John
I had a hard time with my 63 Sport Fury. So I changed water pump outlet to driver side with corresponding rad. and had no other problems. For some reason pass side outlet is way lower than the rad. inlet. I could not find the right hose. it kept sucking closed, just my Experience. Not sure if will help ya ! tried a few diff. ideas as you can See.
Take a coat hanger / TIG filler wire and bend it to fit your "vision" of what you want in a hose, measure spout diameters and then head over to NAPA and have them leave you alone in the hose section while you search out the correct shapes in various hoses. Cut out the area you need from the hoses. Be sure to fit a spring inside the lower hose, or it may suck flat.
View attachment 754168 View attachment 754169
I have a radiator with the lower outlet on the driver side but it was about an Inch from the steering box and down low , no way it would work , that is what made me get the radiator . But thanks John
Thanks that will work , I would think that the pump housing is mopar there has to be a factory hose that would come close to fitting . Thanks John
For the lower hose looks like one from a Slant Six should work.
Many thanks for all your suggestions . I remembered that Speedway Motors has hose kits , aluminum hose spacers for 1 1/2 and 1 3/4 so you can made your own stuff for different combos . I may have to go this way due to the size of the radiator and motor placement . The radiator that had the lower hose on the drivers side ran right into the steering box . Again Many Thanks John
