Aloha, spiders out of an open gear unit will not work !I got a mixed box of spider gears from open 8.25”s , 8.75’s and suregrip 8.75. I’ll check later when I’m home.
In the mean time, post up the diameter dimensions of the gears, so I will have an idea of which gears I should be looking for....
Chuck
Sweet how much buddy ?View attachment 784801 View attachment 784799 Aloha, I’m pretty sure these are from a stock cone type sure grip from an 8 3/4.
So it’s 30 spline, 3 3/4” diameter side gears. (Measured at the largest point, which is from outside of tooth to outside of tooth)
2 3/8” diameter spider gears (Measured as above) with around a 7/8” inner hole for the pin.
Wow, So Way Kool !Just pay for shipping....
I’m sure it’s not easy for you to get parts.
What’s the best way for me to ship them to you? Shipping will be from 10111 NYC
Hi Chris, Any chance you could leave Pos. feedback for all the members that left you positive feedback already? Thanks -TomP.S. Let me be first to Leave you Pos. Feedback. Much Mahalo, C
Happy to, Thought I had. But will fix ASAP. Mahalo CHi Chris, Any chance you could leave Pos. feedback for all the members that left you positive feedback already? Thanks -Tom
MiradaMegaCab... Good on you man![]()
copy that, Been looking for a housing to shorten down. Not much luck yet ! But might have a line on one. also talked to another brother with a Dana posi unit I can buy, Just need Axles and R&P. Some day. No real rush yet !!!no no its a dana type limited slip diff spring loaded clutches spiders , way stronger . i forget your on an inland , but just a 3/4 ton ford dodge of gmc could make it up with new axles . to what ever width your heart desires .
