the Over 10k thread really nice cars
1972 Dodge Charger RT SE ~ $20,000
Private Seller ~ Cedar Rapids, IA
(319) 540-2373 or (319) 247-2886
1972 Dodge Charger RT SE. Triple Black. 440 HP Engine Numbers matching. 4 speed pistol Grip Shifter. Dana 60 rearend. factory hoodpins. front and rear sway bars. 95% RUST FREE. This car was special ordered. I have the original purchase order. Please call 319-247-2886 or 319-540-2373 for any questions and I will be happy to answer them! Thanks!
1972 Dodge Charger Coupe ~ $17,900
Private Seller ~ Beachwood, NJ
(732) 673-2347 ~ Ad# 95999
1972 Dodge Charger Coupe. This 1972 Charger was restored over the past couple years and is a wonderful car for shows and driving. It features its original 318 that was rebuilt 18k miles ago. It has an Edelbrock aluminum intake with Edelbrock 1406 Carb on top, Electronic ignition, factory exhaust manifolds into dual exhaust, 727 Automatic Transmission that was also rebuilt. ARE wheels with radial tires. The interior is original. Dyna mat is installed under the factory carpet for a quieter ride. It has bucket seats and a console, original AM radio, and factory gauges. The body is in excellent condition and was expertly restored. The white paint has blue and green pearl which shines in the sun. A fiberglass R/T hood was installed and a wing on the trunk lid for the added look. A new front bumper was also installed. The brakes were upgraded to front disc, which is all new. It also has its original Broadcast sheet and fender tag showing how it was built from new. This car runs perfect, drives very well, looks great, and is something you can use on the weekends or as a very cool daily driver.
1972 Dodge Challenger Rallye ~ $18,500 obo
Private Seller ~ Seward, NE
(719) 600 7357 ~ Ad# 94366
1972 Dodge Challenger Rallye. This is a 72 Challenger I purchased thinking of restoring it but I have had quite a few health problems and can not afford to keep it. This is a Rallye challenger with a slap stick automatic. The engine is a 80's 360 that should run forever. Has a new intake and a new 650 Holley Carb. It has new tires and rims which have less then 100 miles on them. Front Tire size 19" and the backs are 21". The exhaust is new and has very few miles on it. The fender tag says factory color is G4 which is a fairly rare color. I have other parts such as window seals and door seals for the car but I can not get them on in my condition. Also has a new Kenwood CD with hook up for phone and i pod. Has new 6X9 speakers in back and new kick panels with 4" speakers. There is also a new oem under dash wiring harness in the car. All gauges and tach works and yes the clock also works with new moving parts. This car is a driver not a show car but a car you can hop in and drive. It also has air-conditioning but I don't have a compressor and brackets. If you have any questions please let me know.
1973 Dodge 400 Stroker Motor ~ $12,000
Private Seller ~ Maplewood, MN
(651) 235-5519 ~ Ad# 88757
1973 Dodge 400 Stroker Motor. 400 Low deck stroked to 500 cubes, Ported SR Indy cylinder heads, External oiling system 9 quart pan, Ross forged pistons, Eagle 4340 H-beam rods with ARP 2000 bolts, Eagle 4340 forged crankshaft with cross-bolted mains, Comp cams solid roller camshaft and roller lifters, Harland sharp needle bearing roller rocker arms, Motor is all ARP bolts studs. BG 1050 dominator Carb, Indy cylinder head manifold and aluminum timing chain cover, Indy valley cover, CSR water pump, Mopar performance distributor, MSD wires, ceramic coated headers, aluminum motor plate Dyno sheet available, complete carb to pan.
1973 Dodge Charger SE ~ $18,500 obo
Private Seller ~ Austin, TX
(512) 413-9000 ~ Ad# 87653
1973 Dodge Charger SE. Engine 400 cu. in./ has 40,000 miles/ps/pb/ac/at/. Runs and drives great, in excellent shape inside and out. No damage. Auto Trans. Car pending sale.
1968 Dodge Charger ~ $18,900 obo
Private Seller ~ Brighton, CO
(303) 452-4709 ~ Ad# 85764
1968 Dodge Charger Project (383), currently no motor 383 from Coronet available, will need trunk floor and lower qtrs. (all parts included) original 383 car floor shift auto, 8 3/4 rear available w/ or w/o engine and extra parts.
1970 Dodge Super Bee ~ $15,000 ~ Firm
Private Seller ~ Lagrange, GA
(706) 616-2019 ~ Ad# 83055
1970 Dodge Super Bee. 383, 4 Speed. Metal & body in mint condition. rebuilt 383 & 4 Speed $15,000 plus just in new parts. Just need paint and assembled. $15,000.00 firm cash. Absolutely no negotiating.
Price $ 15,000 NO negotiating Price is firm cash only.
1966 Dodge Coronet ~ $16,500
Private Seller ~ Carrier Mills, IL
(618) 841-2950 ~ Ad# 97928
1966 Dodge Coronet . 440. Originally 318 Car. Has built 440 with 727 Automatic, Shift Kit, 3:55 Sure Grip. Recent Rebuild on Engine, Transmission, and Rear Axle. Newer Paint. Drive anywhere. New Tires and Wheels, Brakes, etc.
1964 Dodge Polara ~ $15,000
Private Seller ~ Havre de Grace, MD
Frank ~ (443) 553-4603 ~ Ad# 92617
1964 Dodge Polara. 440 Motor has mopar cam and high rise intake. 906 heads that have been ported and polished. Holley carburated with electric fuel pump. TTI Big Block headers and 3" Flow master exhaust . Push button 727 with special built converter. Car has all new new brakes, lines, fuel tank, etc. 4:30 posi. Torque Thrust wheels. Re-chromed bumpers. Too much to list. No tire kickers. Call Frank @ 443-553-4603
1967 Dodge Coronet 440 ~ $20,000 obo
Private Seller ~ Seacoast, NH
(603) 770-6015 ~ Ad# 87987
1967 Dodge Coronet 440. Purchased from the original owner in 1986. Originally a 318 that was converted to a 67 440 motor and 727 transmission 17 years ago. The 440 has been rebuilt and has a forged crank and pistons. It has 915 closed chamber heads as well as a mild hydraulic camshaft and dual plane intake. Trans has been rebuilt with a shift kit at the same time and a mild stall converter installed. Excellent running, smooth combination excellent for cruising. Has 2500 miles since completion. Behind the transmission is a custom Dynotech Engineering 3" alum driveshaft, spinning a set of 3.23 gears and factory sure grip unit. Exhaust consists of hooker headers and TTI exhaust system exiting GTX exhaust tips in stainless 2.5".
Suspension is full XV Motorsports level I kit. This includes 1.12 torsion bars, custom alum shocks, f & r sway bars, adjustable strut rods and special leaf springs and urethane bushings. It also has a firm feel stage III steering box. The car corners like its on rails despite the 15" wheel and tire combination. It is a true sleeper. Nobody expects flat cornering from a car that looks like this..It also has front disc brakes, rear drums with a dual diaphragm booster and a vacuum reserve can. Braking system has all new lines and hoses.
The body was original when purchased. The pass side quarter was replaced, but the driver side was patched. All other metal is original to the car. None of the floors had to be replaced. The car was painted 13 years ago and still looks excellent. Painted in VIPER RED. There are some very small bubbles at the bottom of the drivers quarter, front fender and trunk lid lip. Bumpers were redone, all lenses in nice condition too.
All glass except for the windshield is original and in nice condition. Both window gaskets, roof rail and door weatherstrips were changed along the the belt line weatherstrips and door lock seals. All stainless trim is real nice and straight. Sail panel trim could use re chroming but is not damaged in any way.
The interior was redone with new seat covers, carpet and headliner over the last 11 years and looks excellent. The speedometer was replaced with a 150 mph unit as well. Orig radio is in place but does not work. Auxiliary gauges have been added. The original gauges work also. Heat works properly.
This is a very solid and complete car that is ultra reliable and performs excellent. This is a serious car being sold at a fair price from a private owner.
Price $ 20,000 OBO NO TRADES
1966 Dodge Coronet 500 ~ $10,000
Private Seller ~ West Roxbury, MA
(617) 469-3551 ~ Ad# 86246
1966 Dodge Coronet 500. Clean body no rust/rot auto, many new parts runs very good. all org 318 Y block, hood new paint wheels int/like new tel 617-469-3551
I agree with SteveSS, thanks for taking the time to find and post these. There's some interesting cars here.
I really enjoy these threads and I appreciate all the work you do on them Wingfoot.
Greetings Steve & 440RUSH! Thanks for the Kudos! Most of the under $10k listings are retired MOPARS that need mucho work & dinero to get road worthy. There are damn few decent buy and drive MOPARS under $10K! There are exceptions.........
I am pleasantly surprised for a fist full of dollars more, there are so many more reasonably priced MOPAR beauties available as acceptable turnkeys un-touched that most FBBO members would proudly cruise down Main Street, USA; the same goes for cruising Down Under!
Under $10k, BUILD your dream!
Over $10k, DRIVE your dream!
As for me now, I am favoring the OVER $10k offerings! To each his/her own! Luv U Guys!
1964 Plymouth Fury Coupe ~ $20,000
Private Seller ~ Syracuse, IN
(574) 518-0906 or (574) 457-8054
Ad# 99232
1964 Plymouth Fury Coupe. Fresh rebuilt 440 - bored 30 over. 4 wheel power disc brakes. Legendary interior. All glass & chrome good. 391 positrack rear end. Super stock springs. 833 four speed with Hurst shifter. All sheet metal work done. All new front end and much more. Call for details.
1963 Plymouth Fury ~ $12,000 obo ~ MUST SELL
Private Seller ~ Valparaiso, IN
(269) 845-9400 ~ Ad# 90039
1963 Plymouth Fury Project Car. 99% of parts are in hand. Some NOS some original but all is good shape. (Needs windshield and rubber body seals and interior. California Car. Solid body in primer. Needs very minor bodywork. Solid, original floor pans, no rust. Trunk pan is new and installed. Bottom of car has been cleaned and POR 15 is applied to entire under body. Engine compartment is newly painted (black) and ready for motor and tranny. Comes with Sport Fury bucket seats w/console. Must sell this summer to finance new project. 727 push button Torque Flight trans has just been rebuilt. Reverse valve body. 3000-3500 torque converter. 400 big block. fresh rebuild. Roller cam, 906 heads, high rise intake with 650 Holley. HP expected to be 450+
1965 Plymouth Belvedere II Satellite ~ $24,000 FIRM
Private Seller ~ Beaumont, TX
(409) 626-0157 or (409) 839-2322 ~ Ad# 78228
1965 Plymouth Belvedere II Satellite . -Satellite replica, -Built 440 CI engine - Dual 4-barrel carburetors on Cross Ram intake - Keisler 4-speed overdrive automatic transmission - B&M ratchet shifter - Headers and dual exhaust - Power steering - High back buckets w/ Full length console - Cragar wheels with low profile Fuzion radial tires - Pioneer stereo with electric antenna - Cruise control Well proven Power Tour "Long Hauler" Contact Ken @ 409-626-0157. Car located in Southeast Texas (Gulf Coast).
1963 Plymouth Belvedere ~ $19,900
Private Seller ~ Shelton, CT
(203) 366-3747 or (203) 395-5868 ~ Ad# 64225
1963 Plymouth Belvedere Tribute. 413 Motor, 2 EdelBrock 4 barrel carburetor.. NOT ORIGINAL 80% of the interior is original. The front seat cover has been replace as well as the dash pad. The motor has less than 300 miles. This is a very nice car. Tires and brakes are all in working order. Push button automatic! Engine: Excellent, Body: Good, Chassis: Good, Tires: Good, Electrical: Good, Transmission: Good, Paint: Fair, Chrome: Fair. Won a burn out at the Oxford Car Show with this beauty! Trades Accepted!!
1966 Plymouth Belvedere ~ $21,900 obo
Private Seller ~ Fort Myers, FL
Jim ~ (239) 896-2882
1966 Plymouth Belvedere Satellite
440 Super Commando
Auto
AC
Power steering
Buckets/Console
Magnum Rims
Excellent Condition!!!!
$21,900 obo
May trade?
1967 Plymouth GTX ~ $22,500
Private Seller ~ Wentzville, MO
Mark ~ (314) 795-5584
1967 Plymouth GTX 2 door Hardtop
Original drive train 440 4 speed
Dana rear end
Stored for over 25 years
runs and drives
Hard to find an original Mopar like this one
that has not been restored... especially 4 speed ... new tires and also original chrome
Magnum 500 wheels go with car
Lots of mechanical already done
New exhaust with correct tips and fuel system , gas tank, new brakes ,
rebuilt original carb
Lots of horsepower
Also has recored heavy duty original radiator, cost almost $600, just reinstalled in car
Body is better than most, still some small rust as car, has never been restored
Repainted decades ago with a little darker blue than original color
Great restoration candidate with orig engine and trans
Fender tag is there also
314
795
5584
Posted 13 days ago
