69 Charger Hamtramck built front brake lines
Kilrbee
12:22 AM
Wisconsin
Can anyone help me out with a question about 69 Charger Hamtramck built front brake lines? My car has front drums, do the lines run over or under the front frame rails? I'mready to order brake lines and want to make sure I get the correct for my car ones? :thankyou:
The plant doesn't matter....ALL 69 B bodies with drum brakes used the same lines. They go over/under the frame rail.
They go over.
They go over.
Actually over and under...
Thanks for the info guys! The fine lines website is showing two different sets available for the 68-70 manual drum brakes, with the right side either over or under the rail. Can anyone verify the Hamtramck built routing of the right side brake line?
