1963 Plymouth Fury fuel tank fitment
416Blackfoot
4:14 AM
Dallas tx
1963 Plymouth Fury 4r base 318 CID 2bbl
It has a 15 gallon fuel tank.
Is it possible to put a 20 gallon fuel tank
on this vehicle to replace the 15 gallon
fuel tank?
With the stock factory single tank strap setup I wouldn't think about it.
Thank you ..
The tanks was rusted and I sealed it with Caswell tank sealer.
I am looking at buying another tank and thought maybe a 20 gallon tank would fit.
I've never owned anything as old as this vehicle and it looks like I have a lot of Intel to learn about it. I am obliged to you and if there are any other questions MW 413 I will look for you expertise .. Thanks again
I don't know of any B Body tanks that will fit your application stock. Thats not saying another year tank of 19 gallons could be retrofitted. The early B Bodies only have a single tank strap that works fine but later Chrysler did go to a 2 strap setup. I understand mainly because of government regulation as the 1 strap tanks were engineered to separate from the vehicle in a severe accident. (The government thought otherwise.) Stock 16 gallon repo tanks are readily available along with straps, insulation mats, and pick up tube/sending units. Just remember to calibrate your new fuel gauge pick up tube/sending unit to the tank before you bolt it all back together. Hope this helps.
Excellent.. I appreciate your time and knowledge. It's not often that sites you go to for help or guidance readily offer help.
It's usually a bad experience with attitudes
and smart remarks or arrogance..
I'm impressed with this site.
Thank you, MW 413
Thank you, MW 413
You are very welcome.
I'm currently trying to find technical /shop manuals or any material that relates to
This vehicle.
Does your knowledge of Mopars extend from early 60's to 70's ?
What experience do you have in engines?
I will try to post a few pictures of this vehicle if you are interested..
As In sure you know this vehicle has a
318 poly in it.. I can't find any info on that type motor or anything related to it.
Thank you for your help
Keep an eye out on EBay for a 62 service manual. They pop up on there all the time at cheap prices. Yes to answer your question. Like many on here I worked professionally on these cars in the day.
Thank you Truperformance...
1965 Plymouth manual is all they have.
Do they get manuals in on a regular basis?
I appreciate your help.
Thank you
Thank you so much.
What I've found with everyone's help here in 24 hrs, I couldn't get in 4 months from other sites.
Thanks again for your time and knowledge
All new Here, Just like the man said !
I did the exact same !
No doubt about that, 63SPF...
Nice vehicle..
I very much appreciate your help also..
As I go through this vehicle I have I will be asking advice and problem solving questions to you men in the very near future. I did order a 1963 service manual
off of Ebay, 62 SM
I bought a custom 21 gallon S/S tank from Rick's Tanks in El Paso when I switched over to EFI. I added another strap. The trick would be to find another stock tank with the rear filler that fits the space. Adding another strap was not a big deal.
