- 4:30 PM
- Jan 14, 2009
- Shoreline, Washington
What's the advantage on keep the original path on alt side at least? The main splice inside the cab will be still beng feeded from alt by two 12 gauge wires, the one coming from bulkhead and the line coming from ammeter where you are installing the parallel path, thing what won't happen removing the stock one and installing just the larger bypass through the firewall, where is true you can use a 8 gauge wire but the main splice will be still getting just the 12 gauge wire between amm and splice.
Have to challenge one of your points, never suggested removing the original ammeter to splice run, it needs to remain. At 12 gauge, it’s more than adequate for original factory electrical loads, any additional loads should then connect at the alt side ammeter stud or at some point between there and the alternator stud. Still not convinced? you could remove the 12ga splice to bulkhead connector, that would be by-passed, connect it to the alt side ammeter stud, that would double up the splice feed but is really not necessary for stock loads only. There is no electrical need to leave the original charge wires in place if performing this wiring upgrade.
Example of additional non-factory loads.
