Rockett
1969 Road Runner....
My RH inner tie rod end has apparently been nicking my torsion bar with its grease fitting on top. Since removing the grease fitting, it *barely* clears the torsion bar now! LH tie rod clears the torsion bar fine, but I see that my center link is 2" higher end-to-end on the RH side, thus holding the RH tie rod too close to the torsion bar.
So the culprit seems to be the *idler arm* on the RH side (holding the center link 2" higher than the steering gear arm holds it on the LH side). Maybe the wrong idler arm installed?? The only way I could figure that out, would be to buy an idler arm & hold it up next to the one I've got installed.
*However*, in looking at the *bracket* that holds the idler arm to the K-member on the frame, ....mine sure looks "crude". I've attached a slew of photos (you guys like photos, right?
Should this bracket of mine look better than it does? I'm hoping you guys tell me that they all look pretty crude.
(BTW - that's not a "crack" across my bracket, it's like a gouge in the metal there... the photos make it look worse than it is)
If anyone has a 69 Road Runner or Satellite (or other B-body, for that matter) ... Do my photos here look amiss? Would anyone be so kind as to upload photos of what this bracket looks like on their car?
Does the angular profile of this idler arm (below) look correct? Among the different B-body years, I believe there were a couple *different* idler arm part numbers. I'm guessing it wouldn't take much of an angular difference to result in the 2" height discrepancy I have end-to-end across my installed center link.
For that matter, can anyone tell me if their center link is the same height above the road on both ends? I measured at the lowest point on both sides, which is at the forward side of the link, since it tilts a bit towards the front.
As always, any & all comments, questions, suggestions, & photos are very much appreciated!!!
Rick
Rick
