Rockett
...Except that all is good over on the LH side.He said he bought the car recently... im wondering if theres a possibility that the steering box or pitman arm are from a later model and that's what jacked it up like that since his kframe and idler seem to check out Ok???
The center link angles upwards a bit to the RH side & that's where the torsion bar clearance is an issue when there's a zerk fitting in the top of the [very likely aftermarket] tie-rod end.
I would just chalk it all up to the bulky aftermarket tie-rods, except that I'm under the impression that the center link should be perfectly horizontal.
