need info on mounting air grabber switch 1971 roadrunner clone
moparmikee
New Member
11:33 PM
hookstown pa
I am looking for pictures or other information for mounting the air grabber switch under the dash. I have the switch, bezel, bracket and solenoid but cannot figure out how it mounts. I know it is on the left side of dash where I see three holes along with 2 offset drilled holes but not sure how the parts attach. Any help would be great. Thanks Mike
The light switch bracket goes on the inside of the dash frame as it is what the screws grab and pull tight to the dash. It basically slides over the dash frame with the switch lever below and the light bracket above the dash frame. The square cut out below those 2 screw holes is where the light shines through to the switch lever/switch bezel. Hope that helps..
welcome to FBBO
Got it figured out - thanks
