FJ6 v code RR
Hi I have a almost complete 440 steel crank engine. Six pack bottom end is all balanced blueprinted, the block is a standard bore block 4.32 bore size and heads are stock 346 casting. The engine is disassembled for inspection and has grease and all the cylinders and crank bearing journals and no VIN numbers on the Block. Engine can be put back together with no machine work at all. I am asking 2000.
My location is Collins Ohio 44826 I live 5 minutes from the Norwalk Ohio NHRA drag strip summit racing drag strip for anybody who goes to the drag strip racing that is interested in the engine.
If you have any questions please feel free to contact me. Thanks Duane
