FOR SALE 440 steel crank engine
FJ6 v code RR
11:43 PM
Collins Ohio 44826
Feedback: 2 / 0 / 0
Hi I have a almost complete 440 steel crank engine. Six pack bottom end is all balanced blueprinted, the block is a standard bore block 4.32 bore size and heads are stock 346 casting. The engine is disassembled for inspection and has grease and all the cylinders and crank bearing journals and no VIN numbers on the Block. Engine can be put back together with no machine work at all. I am asking 2000.
My location is Collins Ohio 44826 I live 5 minutes from the Norwalk Ohio NHRA drag strip summit racing drag strip for anybody who goes to the drag strip racing that is interested in the engine.
If you have any questions please feel free to contact me. Thanks Duane
IMG_20190905_155010387-4008x3006.jpg IMG_20190905_154952707_TOP-4008x3006.jpg IMG_20190905_154937831-4008x3006.jpg IMG_20190905_154858363-4008x3006.jpg IMG_20190905_154913903-4008x3006.jpg IMG_20190905_154833789-4008x3006.jpg IMG_20190905_154838088-4008x3006.jpg IMG_20190905_154944762-4008x3006.jpg IMG_20190905_154850514-4008x3006.jpg IMG_20190905_154826707-4008x3006.jpg
I believe that is a j440 which would mean its out of a 1973 car, so originally not a 6 pack. .did you remove a 6 pack off of it?
Yeah it's a 73... And has the wrong pistons to be a Sixpack.... It's got the big rods thats all...
the engine is how it came from the factory with all the six packs set up and never came in a car there's no vin stamping for a car or anything on it. all these parts came out of this engine I never put anything in it or took anything off of it there was no six pack setup on it
Didn't a lot of truck motors have the larger (six pack) rods ?
I'm not far from you.
a motor home warranty block
being called a six pack engine... got it..
It shows that words and context matter. There’s a reason people split hairs on certain topics.
