SB 727 Valve body question
chtampa
2:59 PM
Tampa, FL
I have a SB 727 trans and ordering a shift kit. The convertor is Turbo Action and I want the kit to be also. They list 2 different ones and my valve body is not from the existing case. I pulled the pan and the filter only and there was a number 4202528 on the bottom of the valve body. How do I find out the year of the VB? The date wheel on the bottom had either a 86 or 98 in the center.
As far as I know, TA only offers "plate" kits, nowhere as good as the Transgo reprogramming kit.
Turbo Action did not have a kit for that valve body so I am taking a 1973 valve body out of another case. They had one for that VB and it is on the way.
I am not sure which 727 you have but I would not be surprised if you have one with a lockup torque converter. You can identify them by a tube on the top of the valve body..the valve bodies / transmission actually look similar but function differently. You can not put a non lockup valve body in the newer lockup tranny unless you replace most of the internals. I have done it before..but it goes way beyond a shift kit install.
Good, I did finally find your part number you listed as 65-76 727. All the 727s valve bodies in that era should interchange so you should be fine.
as said above go with Transgo for the shift kit
at least call DAVE there first
he'll give you a straight answer either way
