Dana 60
17dodgebros
5:06 AM
pittsburgh
Can anyone recommend a shop in western pa or eastern Ohio that will narrow a truck Dana to use in a 68 b body?
I would suggest calling Wally Allen owner of Allen's Drive Line Service. He is located in Herman, Pa, just south of Butler Pa. His business is located on Renneck Road. Phone #: (724) 282-4003
He is a Mopar restorer. He also rebuilt the Dana 60, A833 trans, and major clutch work on my RS23V0A GTX.
He has the tools to do all Dana 60 work including a case spreader Jack pieces and parts etc. Complete welding facilities including MIG, TIG AND STICK ELECTRODE WELDING. Stands behind his work He used to have a 69 Hemi Super B in plum crazy 4 speed and was building a D-Dart clone car several years ago. He is a friend of Jim Kramer of Kramer Automotive Speciatues in also in Herman, Pa. A well known supplier of NOS MOPAR parts.
BOB RENTON
Not all Dana 60 center sections were compatible with car gearing and other parts.. Know the particulars before you buy.
I did all mine myself. I narrowed an old 1 ton truck rear end. Not a stock set up so the snubber wasn't necessary. I am running Caltracs. Just finished the assembly with a spool and 40 spline gun drilled axles.
View attachment 843942 View attachment 843943
Looks great, I'm doing the same, bought a 60 housing out of a 3/4 ton truck, Just dropped off the housing at the sandblaster. Going to paint it and put it away in the garage till next Spring. Planning on narrowing the housing 47.75 inches flange to flange to work in a mini-tubbed 66 Coronet. Going to run a spool also.
