1970 Roadrunner project
Gregg DeGeorge
6:27 AM
Naugatuck Ct 06770
picked up new project its 1970 Roadrunner post car off this site ,Rh door was junk so found a mint 70 dr on Craigslist no rust widow rolls up and down with ease , problems when I tried to test fit door ,the vent window is hitting the trim when I close the dr ,does a hardtop car have different vent window ..This is probably the nicest used door I ever bought ,the windows don’t seem to fit .I Tryed to loosen vent window to push it down a little thanks Gregg
The glass itself is different between a post and a hardtop. The vent windows should be the same. The hardtop glass has the trim piece that makes up the gap between the quarter glass and the door glass.
This is a charger hard top glass. Edit previously posted wrong glass for the post car..
Both vent frames the same. You need to loosen off the nuts/bolts, screws and allen key head screw that's hidden behind the door panel 1/4" plug etc and adjust/tip the frame to fit the A pillars angle. Door glass is of course different from Coupe to Hardtop.
Agree with dadsbee...post and non post cars different glass
This is a Coronet Post car glass. Which should all be relevant.
got a red X.... even though I said the same exact thing dadsbee said. RETRACT MY X.. Guess I'll throw around some red X's too..
