Wiper motor pivots
Some of them can be saved if not too bad. I have drilled a 3/16" hole in the housing for a grease zerk. squirted penetrating oil in the hole and used some heat on them to loosen them up. Then install the grease zerk and give it a couple pumps. Saved some that way that I thought were frozen forever. Now, I add the zerk to all of them even if they are still operable. Might work for you since they are getting hard to find.
Thank you for the info. I'll give it a try tomorrow
Did the same to mine, they were not seized up, but they now move much more freely an quietly then before the "surgery" . . . .
