Thompson power steering pump question
74RRGTX440
6:30 AM
Iowa
I have a 65 Coronet 500 with a 318 poly, it has the original Thompson blind end power steering pump on it, and it's leaking. I cannot find a replacement pump anywhere, everyone is back ordered indefinitely evidently. How hard is it to convert to a Saginaw pump, or does anyone have the part # for the rebuild kit for the Thompson?
Just need the brackets, pulley and pump. Might need to change the pressure hose, but I’m not 100% on that.
Five years ago I bought a Seal kit for the TRW pump on my '68 Coronet. I have the sales slip with the part number 351390 on it. I'm sure it's a Gates brand. You may want to look into that number and see if it's correct for your pump.
Thank you,I will see if I can find anything using that #
Thanks for the help guys. OK, now for part 2 of the question, I know how to get the pulley off, but my how to do I get it back on? I.m thinking support the shaft in the press, before the reservoir goes on?
That is correct.
I just rebuilt the Thompson on my 66 belvy. Napa kit worked, FYI. Under $20. I have the box somewhere with the part number. Took longer to pull the pump than it did rebuild. One word of caution - when you seperate the housing, the "rotor" has fingers that will fall out, they are directional. Make sure you go slow and mark rotation on these...
Ordered the kit from NAPA this morning, going to give it a try. Thanks for the heads up on the fins.
I thought that Mopar used either Saginaw or Federal pumps. Ford used the Thompson pump. The difference was: Saginaw uses a vane pump design. Federal uses roller pump design and a Thompson used a "cam and roller" design. I must plead ignorance as to the intricacies of the Thompson design as I've not disassembled that type.
BOB RENTON
THANK YOU, the mechanic #15....the presentation is very enlightening and very well explained. I should have realized that Thompson was part of the TRW consortium of Thompson Ramo Woolridge, who make a multitude of car parts. After viewing the presentation, one can see why Mopar went to simpler design in the Saginaw pump.
Thanks again for the education....well done!
BOB RENTON
Here they explain the "new" pumps for 69.
Thanks again for the video.....excellent presentation especially the individual explanations of the flowcontrol relief valve operation....as a side bar....where did you find the old clips of the Mopar techs?? Very well done!!!
BOB RENTON
