WTB 402 oil pan pick up
3white74
6:59 AM
albany,ny
Feedback: 90 / 0 / 1
Wtb .....nice used 402 oil pan pick up...... should be 66-71 b body and 70-71 e body 383 cars that use the 402 oil pan......any one have one laying around,???.... Should look like the one in picture with 2 bends in it.... thanks fbbo
Thanks .... trying for a nice used first
After the Daughter's wedding, not sure I can even get to my engine parts crates, but I'll try in the next day or so. Can't remember if I had another windage tray pick up tube or if it was a straight one..
From the standpoint of a machine shop that does this regularly, you are making a grave mistake using an old used pickup when new (and original) pickups are available. A used pickup will produce up to a 40% reduction in flow due to the varnish (0.005" in thickness) on the screen. The ONLY time I will even consider using an old pickup, is when a NEW one is not available. I then clean the living crap out of it to remove as much of the varnish as possible. You can currently get the Mancini pickup (A Mopar Original) for a measly $29.07 + shipping. Do yourself a favor and get the new one...…..
