Engine Balance Question
beanhead
Easily Offensive
5:50 AM
Wackyfornia
I have a 440 rotating assembly with six-pack rods and Icon 9947 pistons. Balancing was previously achieved by drilling the forged crank. If this crankshaft was to be used with an LY-type rod and lighter piston, would it need to have weight added, or more drilling? Thanks!
Would need to be checked again using the new rods and pistons to make up the bobweight
EDIT; When I read it at first I thought you were swapping to 6 pack rods. 6 pack rods are definitely heavier. Even a stock crank needs an offset balance damper and converter/flex plate. Which balancer and converter flexplate did it use previously? If you used the 6 pack stuff and it was drilled who knows what it is now. Do you have the old balance sheet?
More drilling since it’ll most likely be a lighter bobweight.
