TwoDogs
I want to bleed my brakes using the pressure method, from the brake to the master cylinder. I would pump new fluid from the brake via the bleeder to the master. realizing that the master would be exposed to burping so I will have to regulate the pressure and watch for overflow. I want to know if I there is a risk of damaging anything in the system doing it this way. I have bled systems using the vacuum method and the old fashion pump, open....repeat. I find that using pressure works far better for hydraulic systems. Thank you for your input.
