Detroit Iron
- 3:34 AM
- Jul 30, 2008
- Bay Area - California
I basically want to know if the push rods I'm using are causing my problem.
The 383 (original engine) in my '64 Polara has a sputter that I can't seem to tune out. I've tried multiple carburetors, distributors, ignition boxes, timing settings etc. and still sputter persists. It shows itself on mild acceleration and cruising speeds.
The reason I am looking at push rods at this point is this. When I was building my engine nine years ago, my buddy said he had a brand new set of push rods for a 383, so I used them. They didn't come with a part number and they felt right when I torqued the rocker shafts on, so I went with it.
I recently did some research and found a stock length rod should be 8.645" long. I pulled a rod today and it is labeled 8.600", so I'm looking at a .045 difference. Is that a problem with hydraulic lifters? I also just learned stock should be a non-oiling rod, and the rods in the car are oiling. Is this a problem?
Sealed Power replacements are 8.645, and Melling replacements are 6.635. Could .035-.045 make enough of a difference to make this car sputter?
Here are the engine details:
Original '64 383 bored .030 over
Keith Black Hypereutectic pistons
Lunati 60300 very mild cam
Lunati 71977 recommended lifters
Edelbrock E-street Heads
Rockers are stamped Comp Cams
