aluminum radiator to steel support
charger10
6:07 PM
idaho
I am putting a aluminum radiator in my '67 charger. should anything be put between the radiator and steel support at the bolts? do you keep the radiator up a little off the bottom cross-support?
thanks,
Yes keep it up a bit (check hood clearance) I have used the rubber mounts from MSD that is used as vibration insulators to mount many parts,even the radiator.
thanks, I was worried about the vibration and also possible corrosion between the 2 metals.
