RTclassicfann
- 5:21 AM
- Nov 11, 2016
- Bakersfield, California
Looking at pursuing a 1969 Dodge Coronet RT. The car I'm interested in is a real RT. 440, 4 speed, non console car, 8 3/4 rear end, not sure on the gearing, and they didn't know at the shop. They say they car is numbers matching and has an intact build sheet as well. Here's the rest of the scoop, the rust repair is complete. There will be some body work and blocking to do before paint. The shop that owned it looked inside the engine and all looks good, simple rebuild is needed, although motor isn't running and hasn't run since the shop that owns it has had it.Trans should be good to go. The suspension was taken off the car and cleaned up then put back on. Needs a new clutch assembly. Gaps could use a bit of fine tuning. Glass looks good, as does the rubber, new chrome bumpers and emblems in good shape. the interior is done, but the dash has a cheap dash pad on, so dash could use a little work as well. All wire harnesses look good. gauges look good as well, although not sure if they work since the car is not running. The car was originally Y4 classic Gold Metallic with a Black Vinyl top, stripe delete. The shop says the car is basically 85% complete. Anyway, given the description I have provided, what do you think would be a good price to pay for it. I know I'm asking a difficult question particularly without pics, but any estimation would be greatly appreciated. He asked me to make an offer, any suggestions?
