Mike Gaines
- 12:46 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
After I get the whole car figured out (launch rpm, shock settings, shift points, tire pressure, wheelie bar height, etc) then I will be happy.
Hope to get somewhere NEAR the 8 second bracket, time well tell.
Feb 22/23 is my next outing to get things sorted out.
______________________________________________
Then....I am considering setting up my car with the Fuel Injection Setup I just bought (pictured). I would run Alcohol and when allowed by the track I would certainly add a big shot of Nitromethane.
I ran Hilborns on my Funny Car back in the 60's, running a mix of Alcohol & Nitromethane for "Run What You Brung" Match Racing.
This setup I have is Enderle but the setup is in excellent condition but I need to buy a surge tank, pump, bracket & drive belts and fuel lines, etc. to install the system. I would have about $3500 in the entire setup when done.
Even though "short" tubes are adequate for my current setup (transbrake, leaving at 5000+RPM) I would still want the "long" tubes for the nostalgia look. Hemi Cars ran the long tubes back in the day because they didn't have transbrakes and were launching at around 2000rpm off the footbrake so the long tubes gave then more power down low.
My motor back in the 60's was a 426 Max Wedge and Hilborn only made the short tubes for that setup. (pictured)
