FOUND Throttle Bracket
anthony69runner
11:55 AM
Franklin,NY
Feedback: 35 / 0 / 0
Looking for a throttle bracket that mounts on the intake manifold for a 1969 roadrunner 383 engine with 4 speed.
i have a few throttle brackets will look for the correct one this evening
Ok can you take a picture of it.
These are the exact ones for your application. Same as the Mancini restoration bracket, but original mopar ones. The throttle bracket has the pin on it for auto trans too, you can leave it or grind the rivet off the back side and remove the pin if you don’t want it
How much do you want for them.
Pm me your zip/post code and address and let me see what a reasonable shipping rate is and then I can let you know. Won’t be able to check until tomorrow if that works.
It said I can’t pm you
I only have 6 pm’s in my inbox, shouldn’t be full? Mods?
You can just give me zip code for now on the board if you want...
Just for the heck of it I tried to PM you as well but there’s no option there to start a conversation with you. Also looks like it may have something to do with the fact that your profile view is limited.
