Looking for a throttle bracket that mounts on the intake manifold for a 1969 roadrunner 383 engine with 4 speed.
Ok thanksi have a few throttle brackets will look for the correct one this evening
Ok can you take a picture of it.I have one too, if the other options don’t work for you
How much do you want for them.These are the exact ones for your application. Same as the Mancini restoration bracket, but original mopar ones. The throttle bracket has the pin on it for auto trans too, you can leave it or grind the rivet off the back side and remove the pin if you don’t want it
Sounds goodPm me your zip/post code and address and let me see what a reasonable shipping rate is and then I can let you know. Won’t be able to check until tomorrow if that works.
It said I can’t pm youPm me your zip/post code and address and let me see what a reasonable shipping rate is and then I can let you know. Won’t be able to check until tomorrow if that works.
cant pm youNot sure, others have pm’d me, Anthony, try again. I cleaned up the inbox some more.
11228I only have 6 pm’s in my inbox, shouldn’t be full? Mods?
You can just give me zip code for now on the board if you want...
Ok. I’ll try to look at settings or figure out why pm’s aren’t working?11228
