FOUND Cam shaft for small block
Texas charger 73
5:21 AM
Texas
Feedback: 3 / 0 / 0
Looking for a small block cam. Got a fresh 360, but has stock cam. Want something bigger. Running long tubes, 2800 stall, reverse manual valve body 904,8.25 with 3:55 gears. Csr weighs 3900 lbs. 28" tire. Want something to wake up 360 a little bit, but still be a nice cruiser.
Whatcha got?
https://www.manciniracing.com/mopper8.html
Mopar Performance Parts camshafts are designed and engineered exclusively for your engine. A wide range of profiles are available from mild to wild and bracket to all-out-racing. All MPP camshafts are designed, developed, dyno'd, and track tested by engineers. These canshafts are developed for increase power and rpm potential while maintaining reliability and best possible low-speed characteristics, including torgue and idle quality. MPP Purple Shaft camshafts offer the best horsepower to dollar spent value. Each camshaft package contains the camshaft, cam lube, instruction sheet, and tappets where indicated.
I have a cam and lifters new in the box but I won't be able to get to it until tomorrow afternoon or so. I will see what I can do.
Hey Mike, I am spending the weekend in your backyard.
Whatcha got?
What is your compression ratio & heads.
Compression ratio is stock dish pistons so probably 8-8.5-1. Heads are stock 587 smog heads
Thanks just let me know cause I'm looking to buy something if I can find what I need
I would love a mopar purple. Cam, but I think I would have to replace springs from the stock springs with the lift. Also will stick pushrods work? I trying to see what someone else has cheaper so I can afford new springs, locks and retainers if need, plus I need a double roller
Mine is a Hughes Whiplash SMC1326AL. I have cam and lifters both new in their original boxes. It's a fairly mild cam but has a aggressive idle. These photos are when I got it. It is still in my parts stash but I can dig it out if you need more photos. Send me a PM if you are interested.
Your probably lower than 8:1-1.
IMO, tool a Mike has a good cam for that low compression mill.
View attachment 907359There's a few Whiplash cam videos on You tube. They sure do sound great. Here's that cam in a 318. It will sound more radical in a 318 but you get the idea.
