mrbone
I have a 1968 roadrunner with newly serviced manual drum brakes front & rear.
SYMPTON: Brake pedal is 100% when pumped ounce then applied. But when brake pedal pressure is reduced then applied again, pedal goes to the floor.
The brakes on my first roadrunner I owned in high school would 'fade' the same way.
So I haven't given it much thought.
If it is "normal", is there anything I can do to remedy this?
If not, any ideas what's going on? Seems like bad master cylinder. Wonder if both cars coincidentally had the same problem?
What do you guys think?
THANKS!! AJ
THANKS!! AJ
