Thank You. When I Ordered My Reverse Light Harness It Came With Two Violet Wires, Not a Third Wire For The Reverse Light. Was Just Curious If It Was Only For 69-70
Appreciate The Help. Thank You
Been a fault of mine for 50 years, helping others! LOL The other little wire I have in my hand is getting plugged into the lower right corner of the bulkhead connector for the back up light on my '69 (built Feb 27th or so), but I believe that doesn't happen on the '68, it gets it's power from the drivers door kick panel connector I believe directly from the wire going to the cars reverse lights.. it's been covered here before! Your other single gray wire coming out of that grommet is your tach pick up wire.Thank You So Much!
