65 coronet 4 speed
sam65
8:59 PM
oklahoma
I just bought a 65 coronet 500 4 speed car and the transmission hump looks right from interior but looking from the bottom up it looks like a hack job. Anyone have a picture of the floor from the bottom ?
The factory did do a hack job when cutting out for the shifter hump on these B bodies. Literally looks like a 5 year old did it. Standard practice on 62-65 B bodies with manual floor shifter.
that is exactly what it looks like ! I had a 65 4 speed car years ago but never looked at the hump. Thanks !
If you look close you can see the 4 speed section has been cut out by the factory with a torch. This is a one owner original 383/4 speed '64 Polara.
Yes that is what it looked like laying on the ground looking up.Thank you.
My 66 Dart looked hacked up as well. Torch or air hammer to remove and stick welder to attach it looked like to me. I don't believe they had specific floor pans and transmission humps for stick cars.
I just did my 65 Coronet 440. Verified. Factory 4 speed car.
Yes the floor was FACTORY CUT WITH A TORCH. THATS. THE WAY IT WAS BAVK IN THE DAY. unit was Tagged 4 speed on the line. 1 guy thtew down a templete and turned on the Hot Wrench
I have a 1964 Dodge 440 2 door post with a 426S wedge 365 hp single 4 bbl carb and 4 speed, paint code EE1, that I am restoring over time. When I went underneath to inspect the under carriage, I found the same looking hack job for the transmission tunnel as you did. But I know, having the build sheet, that it is a true factory 4 speed car.
If you check the inner fender tag it will give the transmission code - A3 = 4 Speed A833 manual hurst floorshift. Check it out.
So just relax and enjoy.
