Jimmy Jakobsson
Hi! I did a compression test on my 493 stroker engine with about 400 miles on it, 231/237@050 camshaft, 10,04:1 scr, it have stand now for a few mounth during the off season, i just wanted to see what i have. The compression test show 200 psi on all 8 cylinders, i crank it over 5 times on each cylinder, the gauge swing up to 150psi on the first pulse, 75% of the final value, this must be pretty good on a cold/dry engine, i also skirt in some oil and do the test again and get the same on all 8. I also did a leak down test and that show 13% on all 8 cylinders, that makes me wonder a bit so i contacted Mahle engine components about it, i have their pistons and metric ring pack. He told me that he only use leak down numbers as a secondary information, especially on a metrical ring pack that relies on gas preassure to seal rather than mechanical tension and told me my compression test has great number with my camshaft and that i probably going to have many years of service from my big Mopar. What do you guys think?
