1967 fiberglass hemi hood scoop
Paul_G
3:15 PM
Surprise, Arizona
Is this worth picking up? When I get the 505 installed in the 72 Charger, flat hood, It is going to need a hole cut and a scoop over it to close the hood. He is asking $140 but does need some repairs.
Very nice shape, solidly made. Needs a couple chips fixed and one mounting lug is missing.
At least 20 years old and never installed. approx. measurements are 33-3/4" wide front, 30- 3/4" rear, 35-3/4" side, 3-1/4" tall front, 1"+ rear.
If you buy it re do those cheap *** mounting points unless you want to see it part ways about 80 mph like mine did.
id buy that and fix it before id waste a cent on the stuff made now.
at 140,you could probably offer 100-120 and get it.
Mounting bolts could sure use a bit of reinforcing with no bottom flange.
Call Sled City Fiberglass. Larry will hook you up with top notch stuff.
