I figured I'd try here first... Now that things are moving along with the motor (400/512), I'm starting to get ideas on the cooling system. It's going to be street/strip 64 polara, pump gas 9.5-10:1, block half filled, and trick flow 240s. I want to run an electric fan/water pump. I'm looking for suggestions on which radiator, water pump, and fan I should go with? Is the 22 inch style for our cars enough, or should I go with a later 26 inch style and make my own mounts? I want zero cooling issues at anytime!! Any pics and info is much appreciated.
