What Flywheel with 2892626 bell housing and 1969 440
73RRSunroof
6:25 AM
Utah
I just picked up a cast big block bell housing (2892626). I know I need the 143 tooth flywheel but I see several listed. I am putting it on a 1969 non-hp 440. I believe it is internally balanced.
What flywheel and clutch do you recommend?
do you need an sfi flywheel?
are you road racing or circle track and need super light?
Is this some strip only build?
truck?
give some help here
cheers
truck?
give some help here
cheers
It is just for a mild 440 for street use.
so most any will do and you do not want light with street gears
for a clutch I used to use McLeod Borg and Beck/ Long with lighter springs and lots of weights
on the arms
today there are several options for street clutches and newer disk materials
a long way from finding the stiffest pressure plate you could find-
which bent linkage and broke parts was a lid once
hope you get some good suggestions
