Who makes dust caps for 68 B body with disc brakes
Jim 68cuda
6:54 AM
Virginia
I need replacement dust caps for my 68 Charger RT. The car has front disc brakes and I have tried several different dust caps, but none fit. Either they are way too small or a little bit too large. Body shop lost the well used originals. Any suggestions?
You looking for original BENDIX equipped disc brake parts, or do you have a conversion to any other disc brake parts?
Again, let us know if your looking for original Bendix caps for the hubs, or if a disc brake conversion was done on the car, to some other updated parts.
I have a box full of dozens of grease caps.
+1 for wanting to know who makes proper fitting one for later 73 and up single piston caliper style brake rotors. All the ones I ever tried never seen to fit well and aren’t deep enough
Yes, the car has the original Bendix disc brakes.
You should start a wanted thread.
Got mine from the 'HELP' section at the local NAPA store. Fit fine.
I found a couple used originals locally that fit and I already have them on the car. Thanks for all the input. I may still try the local Dodge dealer for new originals as one person mentioned since the Dorman and other ones I found don't fit.
