signal light problems
471b1dart
9:17 PM
Fredericton NB Canada
Hi , looking for suggestion as what might be going on with my signal lights on my 70 RR, with no lights on or just park lights on my signal lights work fine but if I turn headlights on only on side will blink . Do I have bad headlight switch or blinker switch or dimmer switch? I had changed all my marker lights , park and signal lights ,brake lights to led bulbs and had to use flasher for led lights to get them to work properly . They worked fine for last summer so I think its a switch and not the led lights. Thanks in advance for the help
Sometimes it is the ground, if there is a separate connection for L and R sides. Otherwise you’ll need a volt meter and check for power out to that side.
Guess I should have also stated that the light comes on just doesn't blink when headlights are on
IMHO definitelly ground problem... check the parking light socket is tight with housing and not spinning free.
or even parking light screws to valance
Check grounds. Nacho-RT74 is right. I just fixed the same problem on My 64. Light socket was not making good contact with housing.
