- 12:56 PM
- Oct 16, 2014
- Salisbury, Vermont
Welcome to the best Mopar gang on Earth! Pics before the hanging ropes come out...
Oh yeah I know Steve real well .he bought my old 70 and who I bought the 69 from. ..he has everythingYou need to go see Steve Ivester in Lawndale NC. He can help you a lot. One of the best parts people in the country.
If you have tubbed it with 90* sided tubs, and cut out the outer inside wheel well that curves inward you can get a 15" section width tire under there while dropping the car down over it. With just a mini tub with stock proportions you can get the same tire under there but only drop the car so far.... That's 13 1/2" of tread width. Depending on how high up your tubs are I see no reason a 20" rim and tire would not fit under there. Need the correct backspacing though .It's been a good while since I have been able to do anything .i was diagnosed with brain cancer but I have started working on my car again. It has just went to the body shop and is getting new floors front to rear bumper, full quarter panels,food and fender. I am going to build a fuel injected super charged 440 with trick flow heads. I am also going to run a 727 with gear vendors overdrive. Can someone please tell me what is the widest tire I can run on the rear with relocated leaf springs and lowering blocks. I plan on 18 to 20 inch wheels. Thanks Mark
Thanks ghost rider. I don't plan to tub it outIf you have tubbed it with 90* sided tubs, and cut out the outer inside wheel well that curves inward you can get a 15" section width tire under there while dropping the car down over it. With just a mini tub with stock proportions you can get the same tire under there but only drop the car so far.... That's 13 1/2" of tread width. Depending on how high up your tubs are I see no reason a 20" rim and tire would not fit under there. Need the correct backspacing though .
The foregoing is with the assumption that the RR and the 67 Coronet wheel wells are the same. I have moved my springs inboard and measured from the inside of the lip to the frame and it's 15 1/2". So precise backspacing and perhaps rolling the wheel well lip in for another 1/4" or whatever...
In which case I would guess an old L-60-15 would be the tops. Like 11 1/2" tread?Thanks ghost rider. I don't plan to tub it out
Hey ghost rider. If I were to put mini tubs in how would the trunk hinges work ? Sorry about my ignorance on this . I've never seen one .thanks MarkIn which case I would guess an old L-60-15 would be the tops. Like 11 1/2" tread?
Thanks a lot if you have a chance will you post a couple pictures. . how wide can I go and still use the factory rear seat. Thanks I appreciate it MarkThey work the same. What changes is the tab that is spot welded to the tub gets bent inwards towards the center of the trunk and re welded to the side of the mini tub. The hanger that holds the torsion bars for the lid stays in place. the mini tub kit comes with two strips of steel that are cut to fit in-between the outer tub and the inner once you cut it free along a line that you will get from the kit. separate the halves and weld in the strip, weld the inner halve tub base back onto the trunk floor and axle hump and rear seat ends and you got it. My trunk lid is on gas lifts so I don't have the torsion bars any longer.
