WTB 70 Road Runner hood
1970sat
1:32 AM
Toronto, Ontario, Canada
Looking for a 70 road runner hood, or any 70 satellite hood with a scoop, that will give me more hood clearance than the stock 70 satellite hood.
located in Toronto Canada but willing to drive if needed.
I have a 70 GTX hood that has some rust on the underside near Buffalo NY.
I have an original 1970 Air Grabber Hood. It has rust through on the underside bracing. It needs to be re skinned with the bracing from another hood. $150
I have a 1970 Belvedere Hood, very nice to use as donor or as a factory Belvedere hood. $300.
1970 Roadrunner non air grabber hood, no insert or front trim. Small dimple on leading edge, $450.
Air Grabber Hood door, AMD, and hinge, new never used. $200 + shipping..
Rather not ship, can bring to Carlisle PA, for the Spring show, if it happens or the Mopar show if paid in advance. Have pictures, Send me a message,
Located in the Rochester, NY area, zip code 14564.
power bulge in the middle?
Can you share some pics of the top and underside?
I have a hood. Some bad pics of it right now but can pull it out and get better pics if you want. I can ship also or u can pick up.
ok thank you will let you know about Carlisle
Did you ever find a hood I have excellent one its the one on my avatar picture can send more pictures i bought a air grabber hood for mine $600
amd has them brand new for $349 there was a sale but thanks anyway
What exactly are you @1970sat referring to AMD here? I am in the same boat as you needing more clearance for my 70 and trying to figure out what to do. $349 sounds awfully good!
they had a half price sale going on the stock roadrunner hood but I believe it’s over now. I missed it as well :(
Thanks I am not even sure a stock RR hood would give me enough clearance. Have you found a solution yet?
I’m trying to source an A12 style hood with the scoop, that should do it. It’s a unique look though, not sure if you’re into that. They have them in fibreglass but still big dollars.
Will they fit a 70 Sat/RR? I thought they wouldn’t as the body is different.
